That’s one way to be somebodyHere's some sweet 26" Micky D's:
You can just run the 0W-40, but no oil is going to stop HK engines from grenading. The ESP 5w30 is not meaningfully thinner than the 0W-40. They are both 3.5 HTHS oils.This “brew” was specific to extolling the benefits of both oils for HyunKia GDI engines - perhaps not necessary now with M1 5W30 ESP oil .
When mixing oil formulations to get the benefits of each you often get the benefits of neither.This “brew” was specific to extolling the benefits of both oils for HyunKia GDI engines - perhaps not necessary now with M1 5W30 ESP oil .
One of the things I learned from Dave at HPL is that different additive packages behave differently with different types, and volumes, of friction modifiers in terms of enhancing wear protection and reducing friction. So say a dimer/trimer moly blend top-treat is enhanced by a dash of tungsten in a Euro additive package, that same combo could actually perform worse than just straight-up trimer in an API-spec additive package (these are not real examples, just illustrating the point).The thing about Frankenbrews is that you are potentially trying to get oil together than is greater than the sum of its parts. Mixing across grades because you have something lying around is bad.
ExactlyTwo quarts ? Run it ...
I’m lovin’ itHere's some sweet 26" Micky D's:
since its impossible to know its easy to say no bad results or "show me the issues" none of which are immediate or critical.This drove me to check the shelves - and thinking of two rules of thumb seen here often. Stay with brand and stay with grade.
I have Valvoline in quart bottles that are all 10W30.
2 are full synthetic HM
2 are semi in HM (these are only $6, so two more is doable)
1 is VR-1
So who thinks that mix will cause issues in a Pentastar for 5k?
(and no, my OPE has plenty of stash)
I can’t take credit for the above oil brew but I believe this and maybe other brews posted here worth a glance .Because Mobil didn’t know what it was doing when it formulated either one of those oils, but poured together in ways that Mobil never tested, it’s now a magical elixir?
Forgive the spelling- but what about the former “Cateran” oil blend popular here for Toyota owners - quite a few members here liked it . No matter , I don’t blend and will most likely continue with M1 5W30 EP or M1 0W30 ESP oils .Worth a glance as in when somebody tells you there's a Monte Carlo decked out in a McDonalds paint job, rolling on 44" rims and you take a peek, because it's worth a glance?
Worth a glance as in when somebody tells you there's a Monte Carlo decked out in a McDonalds paint job, rolling on 44" rims and you take a peek, because it's worth a but what about the previous “Caterand” oil blend for Toyotas - member
Yes, the "CATERHAM blend" which I was always vocally critical of, if you recall for the same reasons I've outlined in this thread.Forgive the spelling- but what about the former “Cateran” oil blend popular here for Toyota owners - quite a few members here liked it . No matter , I don’t blend and will most likely continue with M1 5W30 EP or M1 0W30 ESP oils .
Did you complete the oil change? I see no mention of Marvel Mystery Oil.I think you will be OK, I’ve mixed all all of my life in several variations and weights, I changed the oil today in my Jeep. I mixed Mobil one with Lucas and added Lucas oil additive.
I’ve got Marvel mystery oil in my shop, but I’ve never really used it. It’s more of an engine flush some like it some don’t . I don’t really use it.Did you complete the oil change? I see no mention of Marvel Mystery Oil.
Why would you adulterate a good oil like that?I think you will be OK, I’ve mixed oil all of my life in several variations and weights, I changed the oil today in my Jeep. I mixed Mobil one with Lucas and added Lucas oil additive.
Maybe he's still here in one iteration or another.You are thinking about the member Caterham and he hasn’t been here since 2020.
