Tons of good info in here.
I feel that the suggested btu for a basement room is NUTS. basements are cold naturally.
even if you get a system that can vary between 20-100% it still might not be dehumidified well.
I would undersize.(if it makes sense is it even "undersizing"?)
if it runs 100% of the time at 100% (highly unlikely) you could always help it out with a vent or 2 from the main house A/C as worstcase/last resort for that one week of 110F heat per year.
The basement already stays 5-10f colder than upstairs with the existing cooling. no need to add 2 tons more of A/C to an underground room.
The sun room on the other hand could be all over the place got a decent pic or 2 you could share.
the sunroom is under a porch? so is it mostly shaded? how much actual sun directly shines in the room.. esp between 10am and 6pm.
Will it get any cooling from the basement or be totally separate.
There should be not much heat from above? ie not like sun beating down on a roof above upstairs bedroom.
If you answered any of this earlier I missed it on phone.
