On the way home I stopped at gas station to fill up, and get gas for myself(beer). while filling up I checked oil, and saw that I got melted fuse on hot wire that goes to HID kit,that I got about a month ago. It works perfect, no problems at all. Almost all plastic melted away, but fuse is not blown.
I tried to research a little, and found couple topics with same problems.
Some people say it is just cheapo fuses, swap it out if you can(if metal did't melt inside). Or it is too "thin" hot wire that heats up a lot. Then, I'll wait with that till it warms up outside.
I installed same brand kit on my Fathers truck(he has bad vision), will check his fuse later on.
I remember his instruction said something about upgrading factory fuses to 20A or 30A in case of troubles.
I have not upgraded any fuses.
Any thoughts guys?
Any thoughts guys?
