Originally Posted By: JTK
Does the 2011 Elantra have a drain plug and dipstick on the AT? If so, it will be easier than an engine oil change. If not, I don't blame you at all for wanting to have it done.
FWIW, the last Hyundai product I used Maxlife ATF on was my 2008 Hyundai Santa Fe AWD with the F4A51 AT. It worked great in it for the ~36K-76K miles I kept the vehicle. The factory ATF was as black as well used motor oil at 36K miles. I had a thread on it back then.
You know YOU TUBE is a great tool to use when you want to see DIY videos of how to do just about anything on yor car.
I tell people that at work all the time when they ask me how to change certain parts on there cars for instance starters.
Then they come back and return the core and say WOW you were right it was very easy thank you.
Also about the fluid Idemitsu Type HK should be spec for your car and you should be able to find at a good price locally
