Boat engines do have a harder life. In a car, going down the freeway you need very little gas to keep going and if you let off the gas you coast. In a boat you need a lot of gas to keep going and if you let off the gas you stop. Also boat engines live in a tough environment, are over-cooled and spend a lot of time idle. It is often times difficult to change the oil, that is get to it, get all of it and dispose it. I had a 40' sail boat, used synthetic oil and had double Frantz oil filters. I used a uoa to determine the best oci and bypass filter change interval. With an outboard I would run synthetic and change it frequently. I would justify an oil analysis by saying it's a learning experience for me, not just for the motor. Sometimes you lean best when you figure out things for yourself.
