I stick a short bolt in the bottle end of the hose then cut a slit in the hose just above it.
Now what does THAT do?
It helps to keep air out of the line on the return stroke. The slit opens when fluid is being pushed out and then closes back up when the pressure stops.
If the end of the hose is submerged in brake fluid what difference does it make?
Could all of these methods pull air in from around the threads of the bleed screw when the pedal is let up?
If you make this you will find the plastic bottle with the hose attached and empty will not stand up very well. With the slit in the end it makes no difference how much fluid the hose is stuck in.
And yes they do allow air to be drawn in past the thread. I will use some paste type Teflon sealant on the threads.
