Magneto Switch Question???
Tom, I had to mention this before everyone starts laughing, because of the "Milk of Magnesia" comment.
I remember reading in a Hot Rod magazine that Milk of Magnesia was indeed an excellent substitute for anti-seize compound....
On the other hand, I wouldn't take anti-seize for an upset stomach...
it's true. 6 million dollar engine and we are applying phillips MOM on the ignitors per GE recomendations and the USAF T.O. system. of course it has to come out of the haz-mat pharmacy and you have to read the msds before using it "just in case" you were to get some on your skin, god forbid you accidentally ingest some
it does actually work. it is generally used for high heat areas.
RE Anti- seize on spark plugs....it was used on round engines in the Pacific Theater in WWII and made the plugs easy to remove for service after a mission, even in the humid, salty island climates. Worked well applied sparingly to the first few threads. However...from a friend who was there...a couple of young geniuses serviced the plugs on a B-29, a couple of days long project, in record time by just dipping the business ends of the plugs in a can of anti- seize and torqueing them in. The metallic particles....well, you know the rest. This led to a panic ban on anti-seize on plugs, later picked up by the FAA, which only allows a thin graphite-containing liquid to be used on plugs.
There is always a reason for the crazy things you find in aviation methodology. Basically, nothing can be made fool-proof, because fools are so darn ingenious.
Terry, this thread seems to obey Henry Kissinger's law of academic battles: "The battles are so bloody because the stakes are so small."
I suppose his law applies equally to aircraft trivia. Now knowing more than I have ever wanted to imagine about the subject, a few calls to accessory builders seems to indicate that 10%-15% of their magneto business involves dual-impulse systems, and those are tending to be small Continental engines. This is far more than we would have imagined, although far from being ubiquitous as well. Of course the original question was why the switch read R-L-BOTH, and that is obvious if you consider how the switch has to be engineered: L has to be next to BOTH, whether you put the label on top, bottom, or sideways.
Related question is why have two impulse couplings at all? Positives: engine MAY start a little easier (but that's a stretch). Negatives: More weight; more complexity; no performance advantage; decreased reliability in cruise; engine may start with one coupling damaged, leading to a gear-train crash in flight causing total engine failure (and this is the biggie, not to be ignored). Possible answer: may market better to aircraft mfr. or be a sales point to a customer, many of whom like to buy everything they can get to put on their airplane, whether it makes sense or not. At the time, engine manufacturers probably were told the couplers were bulletproof. However, numerous ADs in the late 90s regarding coupler wear and in-flight failures should inspire caution, and older couplers should be updated to the snap-ring design..
Regarding anti-seize, no Darrell, your message is informative, nothing to waste a bullet on. Thank you for your comments. I don't make a living as an aircraft technician, but I have removed a few seized plugs in racing engines, and aircraft, and my low-hassle method is to wrap a few rags around the plug, pour some liquid N2 on the rags to saturate them, and wait for the 'plink', usually less than a minute, then unscrew the plug with a leather-gloved hand or a plug wrench. A gallon of N2, ferried from the welding shop in a plastic water cooler, is plenty, and worth the trouble for a $4000 head, or an aircraft cylinder..safe and easy.
The WWII spark plug anti-seize was originally metallic, until the Pacific incident, then they switched to "anti-seize, spark plug, graphite and petrolatum". I'm looking for a can, has a MIL number. Good because it is non-metallic and burns off the plug tip, clearing a short, but only moderately effective. The Champion anti-seize is a thin-film graphite coating, safe but not too effective, as my plugs squeak and groan when they are removed after using the stuff. I prefer to use a thin coat of Bostick Never-Seez, the medium nickel-rich grade. I have used this stuff on Hastelloy C and Inconel X-750 tubing and Swagelock fittings carrying anhydrous HF gas at 500 degrees C, and it was, of all we tested, the only anti-seize which would work a t these extreme conditions without galling, allowing the fittings to be reused. To use it on aircraft plugs, wipe a thin coat on the threads, and wipe off as much as you can. It's flawless, as long as you torque to about 85% of recommended torque.
