Fresh Voa of Mobil1 fs European formula.
Code
Sample Date 1/22/2019
Sample # 40376
Lab #
Analyst
Unique ID 40376
Wear Status 0
Cont Status 0
Chem Status 0
Unit Usage
Oil Usage
Oil Added
Aluminum 1.78
Antimony 0
Barium 0
Boron 277.25
Cadmium 0.26
Calcium 3,018
Chromium 0
Copper 0.04
Iron 1.3
Lead 0
Magnesium 23.12
Molybdenum 89.5
Nickel 0
Phosphorus 893.6
Potassium 2.03
Silicon 5.96
Silver 0.04
Sodium 3.58
Tin 0.36
Vanadium 2.1
Zinc 1,181
Manganese 0
Titanium 0
Add Depletion 95
Ferrous Idx
AntiOx Deplete
Antiwear Comp
Free Water
MxD Ct >20 4
MxD Ct >25 1
MxD Ct >50 0
MxD Sl >20 1
MxD Sl >25 0
MxD Sl >50 0
MxD Ft >20 11
MxD Ft >25 0
MxD Ft >50 0
MxD Ox >20 10
MxD Ox >25 3
Cnts >4 9,442
Cnts >6 2,127
Cnts >10 491
Cnts >14 160
Cnts >18 9
Cnts >22 2
Cnts >26 1
Cnts >32 0
Cnts >38 0
Cnts >56 0
Cnts >70 0
ISO >4 20
ISO >6 18
ISO >14 14
Glycol Vol 0
IR Oxidation 11.53
IR Soot
IR Nitration 4.95
IR Water
IR Hcarbs
IR Glycol
IR Anti-Wear
IR Sulfation 34.27
Visc 40C 70.7
Visc 100C 13
Visc Idx 186
MxD Ox >50 1
Total Acid
Total Base 12.61
Foam Tend 1
Specific Gravity
Solids Vol
MxD Ot >20 1
WDA Severity
Ferro Large
Ferro Small
Fuel Vol
PC Vol < 6u 0.44
PC Vol 6-14u 0.66
PC Vol >14u 0.34
Soot LEM/TGA 0
Soot Vol
MxD Ot >25 0
PPM Water 247
MxD Ot >50 0
Total Fe 0
Total Non Fe
Fe >21
Fe >25 0
Fe >50 0
Fe >100 0
Fe >38 0
Fe >70
Mobil 1 Extended Performance 5w30
Code
Sample Date 1/15/2019
Sample # 40349
Lab #
Analyst
Unique ID 40349
Wear Status 0
Cont Status 0
Chem Status 0
Unit Usage
Oil Usage
Oil Added
Aluminum 1
Antimony 1.97
Barium 0
Boron 93.01
Cadmium 0.05
Calcium 1,067
Chromium 0.03
Copper 0.02
Iron 0.8
Lead 0
Magnesium 570.33
Molybdenum 85.8
Nickel 0
Phosphorus 678.73
Potassium 0.9
Silicon 3.92
Silver 0.04
Sodium 6.87
Tin 2.4
Vanadium 2.15
Zinc 913.81
Manganese 0.07
Titanium 0.28
Add Depletion 99
Ferrous Idx
AntiOx Deplete
Antiwear Comp
Free Water
MxD Ct >20 2
MxD Ct >25 1
MxD Ct >50 0
MxD Sl >20 6
MxD Sl >25 4
MxD Sl >50 0
MxD Ft >20 4
MxD Ft >25 3
MxD Ft >50 0
MxD Ox >20 8
MxD Ox >25 8
Cnts >4 1,094
Cnts >6 250
Cnts >10 75
Cnts >14 33
Cnts >18 15
Cnts >22 11
Cnts >26 9
Cnts >32 5
Cnts >38 2
Cnts >56 1
Cnts >70 0.7
ISO >4 17
ISO >6 15
ISO >14 12
Glycol Vol 0
IR Fuel
IR Oxidation 7.42
IR Soot
IR Nitration 1.26
IR Water
IR Hcarbs
IR Glycol
IR Anti-Wear
IR Sulfation 14.17
Visc 40C 61.3
Visc 100C 10.9
Visc Idx
MxD Ox >50 2
Total Acid
Total Base 8.26
Foam Tend 1
Specific Gravity
Solids Vol
MxD Ot >20 2
WDA Severity
Ferro Large
Ferro Small
Fuel Vol
PC Vol < 6u 0.05
PC Vol 6-14u 0.08
PC Vol >14u 0.38
Soot LEM/TGA 0
Soot Vol
MxD Ot >25 2
PPM Water 0
MxD Ot >50 1
Total Fe 0
Total Non Fe
Fe >21
Fe >25 0
Fe >50 0
Fe >100 0
Fe >38 0
Fe >70
Code
Sample # 40376
Lab #
Analyst
Unique ID 40376
Wear Status 0
Cont Status 0
Chem Status 0
Unit Usage
Oil Usage
Oil Added
Aluminum 1.78
Antimony 0
Barium 0
Boron 277.25
Cadmium 0.26
Calcium 3,018
Chromium 0
Copper 0.04
Iron 1.3
Lead 0
Magnesium 23.12
Molybdenum 89.5
Nickel 0
Phosphorus 893.6
Potassium 2.03
Silicon 5.96
Silver 0.04
Sodium 3.58
Tin 0.36
Vanadium 2.1
Zinc 1,181
Manganese 0
Titanium 0
Add Depletion 95
Ferrous Idx
AntiOx Deplete
Antiwear Comp
Free Water
MxD Ct >20 4
MxD Ct >25 1
MxD Ct >50 0
MxD Sl >20 1
MxD Sl >25 0
MxD Sl >50 0
MxD Ft >20 11
MxD Ft >25 0
MxD Ft >50 0
MxD Ox >20 10
MxD Ox >25 3
Cnts >4 9,442
Cnts >6 2,127
Cnts >10 491
Cnts >14 160
Cnts >18 9
Cnts >22 2
Cnts >26 1
Cnts >32 0
Cnts >38 0
Cnts >56 0
Cnts >70 0
ISO >4 20
ISO >6 18
ISO >14 14
Glycol Vol 0
IR Oxidation 11.53
IR Soot
IR Nitration 4.95
IR Water
IR Hcarbs
IR Glycol
IR Anti-Wear
IR Sulfation 34.27
Visc 40C 70.7
Visc 100C 13
Visc Idx 186
MxD Ox >50 1
Total Acid
Total Base 12.61
Foam Tend 1
Specific Gravity
Solids Vol
MxD Ot >20 1
WDA Severity
Ferro Large
Ferro Small
Fuel Vol
PC Vol < 6u 0.44
PC Vol 6-14u 0.66
PC Vol >14u 0.34
Soot LEM/TGA 0
Soot Vol
MxD Ot >25 0
PPM Water 247
MxD Ot >50 0
Total Fe 0
Total Non Fe
Fe >21
Fe >25 0
Fe >50 0
Fe >100 0
Fe >38 0
Fe >70
Code
Sample # 40349
Lab #
Analyst
Unique ID 40349
Wear Status 0
Cont Status 0
Chem Status 0
Unit Usage
Oil Usage
Oil Added
Aluminum 1
Antimony 1.97
Barium 0
Boron 93.01
Cadmium 0.05
Calcium 1,067
Chromium 0.03
Copper 0.02
Iron 0.8
Lead 0
Magnesium 570.33
Molybdenum 85.8
Nickel 0
Phosphorus 678.73
Potassium 0.9
Silicon 3.92
Silver 0.04
Sodium 6.87
Tin 2.4
Vanadium 2.15
Zinc 913.81
Manganese 0.07
Titanium 0.28
Add Depletion 99
Ferrous Idx
AntiOx Deplete
Antiwear Comp
Free Water
MxD Ct >20 2
MxD Ct >25 1
MxD Ct >50 0
MxD Sl >20 6
MxD Sl >25 4
MxD Sl >50 0
MxD Ft >20 4
MxD Ft >25 3
MxD Ft >50 0
MxD Ox >20 8
MxD Ox >25 8
Cnts >4 1,094
Cnts >6 250
Cnts >10 75
Cnts >14 33
Cnts >18 15
Cnts >22 11
Cnts >26 9
Cnts >32 5
Cnts >38 2
Cnts >56 1
Cnts >70 0.7
ISO >4 17
ISO >6 15
ISO >14 12
Glycol Vol 0
IR Fuel
IR Oxidation 7.42
IR Soot
IR Nitration 1.26
IR Water
IR Hcarbs
IR Glycol
IR Anti-Wear
IR Sulfation 14.17
Visc 40C 61.3
Visc 100C 10.9
Visc Idx
MxD Ox >50 2
Total Acid
Total Base 8.26
Foam Tend 1
Specific Gravity
Solids Vol
MxD Ot >20 2
WDA Severity
Ferro Large
Ferro Small
Fuel Vol
PC Vol < 6u 0.05
PC Vol 6-14u 0.08
PC Vol >14u 0.38
Soot LEM/TGA 0
Soot Vol
MxD Ot >25 2
PPM Water 0
MxD Ot >50 1
Total Fe 0
Total Non Fe
Fe >21
Fe >25 0
Fe >50 0
Fe >100 0
Fe >38 0
Fe >70
