2010_FX4,
I notice you're referring to the new M1 0W-20EP as the "EP version of AFE".
I think this is incorrect. The AFE versions use lower amounts of phosphorus and zinc (650/750ppm vs. 800/900ppm for the other SN oils), per the Mobil 1 comparison chart.
The lower additive levels reduce the friction improving the fuel economy, albeit slightly. Better base stocks, with likely a higher PAO content, allow longer drain intervals (due to improved oxidative control), in spite of the lower level of antiwear agents.
In the EP versions, the base stocks are most likely very similar to the AFE versions, but the zinc/phosphorus levels are increased to the standard M1 levels. The result is better wear control at more extreme oil change intervals.
I think the new M1 0W-20EP formulation is tweaked and optimized compared to M1 0W-20 AFE or M1 5W-20EP.
XOM clearly recognized this viscosity is overtaking 5W-30 as the one to put all the research & development into.
Since you probably could have easily gone 20k+ on the 0W-20 AFE, I have no doubt this oil could be worth 3-5k extra miles. I, for one, can't wait for you to begin your rigorous testing of this oil in your Ford. ;-)
Take care,
Gary
