From Polaris Labs.
Element, VOA, 6856 mi, 7524 mi
Wear Metals.
Fe: 0, 20, 25
Cr: 0, 1, 1
Ni: 0, 1, 1
Al: 0, 4, 6
Cu: 0, 25, 25
Pb: 0, 4, 4
Sn: 0, 0, 1
Contaminant Metals.
Si: 5, 14, 17
Na: 2, 9, 9
K: 0, 2, 4
Multi-Source Metals.
Mo: 75, 174, 160
B: 155, 88, 76
Additive Metals.
Mg: 405, 378, 365
Ca: 1968, 2275, 2165
P: 889, 961, 898
Zn: 1023, 1092, 1096
185224 miles
1 quart added between samples.
Fuel Dilution % vol: 0, 0.8, 1.0
KV100: 12.4, 12.5, 12.7
TBN: 9.7, 3.9, 3.7
Oxidation: 18, 41, 40
Nitration: 7, 14, 14
Polaris Comments: Infrared results indicate oxidation is severly high. Base number is slightly low.
Not a lot of miles between oil samples on this one, but I thought it was important to get the effect of three track days in hot weather. I thought oxidation was going to be worse but it seems to have stabilized, and the base number was getting close to Polaris' 35% threshold for a change recommendation. The KV100 has been on a slight upward trend over two samples. Maybe this oil could have gone longer, but not by much. I now have Redline 5w30 in it.
Wear Metals.
Fe: 0, 20, 25
Cr: 0, 1, 1
Ni: 0, 1, 1
Al: 0, 4, 6
Cu: 0, 25, 25
Pb: 0, 4, 4
Sn: 0, 0, 1
Contaminant Metals.
Si: 5, 14, 17
Na: 2, 9, 9
K: 0, 2, 4
Mo: 75, 174, 160
B: 155, 88, 76
Additive Metals.
Mg: 405, 378, 365
P: 889, 961, 898
185224 miles
TBN: 9.7, 3.9, 3.7
