LSPI is primarily caused by the calcium detergent -- hence why SN PLUS oils have magnesium with reduced calcium.
GDI intake-valve deposit (IVD) is a complicated business. One thing that's clear is that lower NOACK (= thicker oil) increases the IVD, as the oil sits longer on the valves before it can evaporate. Therefore, if you have a GDI engine, you might want to stick with 0W-16 or 0W-20 if they are recommended viscosities.
Conventional wisdom -- thicker oil and lower NOACK protects better -- fails here.
This is very similar to fuel-caused IVD in port-fuel-injection engines (PFI). They found that fuels containing high-boiling-point (low-volatility) compounds were the main source of the deposits:
"The deposit analyses suggested aromatics (including PAH) with a high boiling point or used at high concentrations tend to remain on the valve surface as a deposit."
However, they also found that:
"A high final boiling point of the fuel does not necessarily make a fuel more prone to IVD formation, but rather it depends on the chemical composition of the high boiling components."
Meaning that, in addition to having a lower boiling point (higher volatility), the oxidation stability (quality) of the fuel compounds is also critical to reducing the IVD. In GDI engines, where oil and EGR are causing the IVD, the analog is that a higher-quality base oil (PAO or GTL) that is thin (higher NOACK, such as 0W-xx oils) is needed to reduce the IVD.
An Intake Valve Deposit (IVD) Engin...t Build-Up Mechanism Using a Real Engine
Sandro Gail -- Shell Global Solutions (Deutschland) GmbH
Takashi Nomura -- Toyota Motor Corp.
Hitoshi Hayashi -- Toyota Motor Corp.
Yuichiro Miura -- Showa Shell Sekiyu K K
Katsumi Yoshida -- Showa Shell Sekiyu K K
Vinod Natarajan -- Shell Global Solutions (US) Inc.
October 8, 2017
Therefore, to reduce GDI IVD: Use a (1) higher-NOACK 0W-xx oil [meaning thinnest base-oil possible] (2) with the highest-quality base oil and (3) lowest SAPS. Avoid full-SAPS (FS) oils such as A3/B4. If 5W-20 is recommended, use 0W-20 to have higher NOACK. If 5w30 is recommended, use 0W-30.
There are several components to IVD: "a combination of engine oil, engine-wear elements, unburned fuel, and exhaust gas contaminants" according to the following nice SAE/Afton paper.
Note that EGR is also a critical factor. As I noted before, it's the PCV oil mist, not oil vapor, that forms the deposits.
Formation of Intake Valve Deposits in Gasoline Direct Injection Engines
Gregory Guinther -- Afton Chemical Corporation
Scott Smith -- Afton Chemical Corporation
October 17, 2016
SUMMARY/CONCLUSIONS
* A standardized, vehicle-based GDI IVD test has been developed that is both repeatable and responsive to known additive chemistry.
* Higher engine loads lead to an increased rate of deposit formation.
* IVD formation in this protocol is an oil-related process, and the majority of the oil that finds its way onto the intake valves comes from the PCV system.
* The oil leaving the crankcase through the PCV system is whole oil containing additives and contaminants (not distilled base oil vapor which contains no additives).
* PCV gas flow in the intake manifold is inconsistently distributed among the eight runners of the manifold leading to the valves.
* Inhibiting the carbon-formation process lessens the rate of deposit formation on the intake valves.
* Oil consumption past the rings bring both additive and nonadditive elements into the combustion chamber where they are incorporated into the exhaust-gas particles.
* Particles found in EGR exacerbate deposit formation rate.
* Particles found in EGR appear to incorporate combusted oil additive components, engine wear metals, and ambient air contamination.
