I've been running my Dodge SRT4 for over 2 years now. It runs a turbocharged 2.4 L engine, max boost is 19 psi, and it runs pig rich with fuel at WOT. For the most part I run Mobil1 10w30. The engine used very little oil the first year I had it, usually 1/4 quart between oil changes. I then installed a Mopar stage 2 upgrade and since then oil consumption has been worse, about 1 quart between oil changes. The stage two kit increased max boost to 19 psi from 14 psi, and added a ton of fuel making the air fuel ratios pig rich. I also had the same consumption levels running Redline 10w30. My OCI's are 3000 miles in order to keep the warranty guys happy.
For some reason oil consumption just irritates me, I prefer to have an engine maintain oil levels between changes if it's possible. Can anyone recommend an oil that might have less consumption ?. I'd prefer to stay in the 30 weight range if I can, since this engine uses a balance shaft system and the bottom end has absolutely no windage protection. A 40 weight may make it sluggish.
I'm not sure what's made the consumption rise, I don't drive it very hard, and the engine seems mechanically sound. I'm wondering if the extra fuel is doing something to make the oil more volatile. UOA's I've had done show wear numbers as being very low, with no fuel or water in the oil, & it runs quite well on a dyno - 260 whp and 280 ft lbs to the front wheels. Never any blue smoke out the tail pipe eithre. If I knew where the oil was going I might be less concerned, but I am wondering if the piston rings are seizing up with varnish or something like that.
Any suggestions on an oil that might work better in this setup would be appreciated, thanks very much.
