Originally Posted by Shannow
Originally Posted by A_Harman
As far as I know, Zinc is not a cat poison. Since it comes with Phos in zddp, maybe some people mistakenly blame it even though it is the Phos that is the "bad actor". It is the Phosphorous level that the API limits in its specifications, not Zinc.
http://www.savantgroup.com/ASTMSym04-PEI.pdf
Quote
Phosphorus Concentration Reduction and Concerns - A more challenging and debated direction in limiting phosphorus volatility was to limit the concentration of ZDDPs in the engine oil. Understandably, this brought intense discussion among automotive and lubrication engineers about
1. lowering levels of ZDDP in engine oils without considerable field experience in modern high-performance engine durability, at a time when
2. engine oil operating viscosities and levels of hydrodynamic lubrication were being reduced to gain fuel efficiency, as well as concern about
3. the impact of such changes on older, used, and presumably more vulnerable automobiles.
Despite these concerns, phosphorus levels were reduced first to a maximum of 0.10% in lower viscosity grades passenger car engine oils designated API SJ and ILSAC GF-2 in 1995 and then, in 2004, to a level of 0.08% for API SM and ILSAC GF-4.
Gonna dredge this one back up. Does the above seem like reliable information? The link is dead, and I haven't seen much discussion on this topic through web searches. I just now was able to log in here and use the forum search. I typed in "catalytic converter phosphorus". Looks like I have some reading to do.
Why I'm asking is I have a couple 5 gallon buckets of 5w-40 Mobil Delvac ESP. Currently in use in our 5.9 Cummins and I'd like to use it in our QX56 as well.
The Infiniti calls for API Service SM
The Delvac I have here says: CJ-4,CI-4 PLUS,CI-4,CH-4/SM,SL
Seems like it should work fine, but I'm still just a little concerned about the stupid cats. I was kinda hemming and hawing about using this without knowing if the phosphorus would be a problem. I was planning on just using it and then I thought I better try to do a little research. The Infiniti was bought used well out of warranty 3 years ago and has just under 150,000 miles on it.
