I am in the middle of doing another Honda Odyssey 3.5 VTEC with VSA light and CEL ON.105K 7.5K OCI
This is another sludge and varnish job.I cleaned the screen in the VTEC unit and valve then reassembled it and added 16oz Kreen for 1K.
The sludge was liquefied,with no chunks when i drained it.
A liquid black thick soup was on the bottom of the drain pan,i will take pic when i get back to this car later in the week when this snow storm eases up.
The plan now is to remove the valve and filter mounting plate,check for sludge in the passage and install new screen and gaskets then run Kreen 3x over a 3K OCI.
VSA and CEL is now OFF.
These engines seem to be problematic with 7500 plus OCI,i see a lot that have 4-5K OCI that are clean inside and problem free.
The PCV on both these was clear and had been changed.
We plan to run Mobil 1 ESP 5w30 after the cleaning,it seems to work very well in these and the Nissan VQ engines for 7500 OCI.
