kohler oil filter?
Texas
I have a Kohler 17.5hp and it calls for a oil filter #52. Is there another oil filter that I can use?
Her's some choices. If I recall the 17.5 Hp has a boos near the filter, so the biggest you can go is the 3.4in length.
"Briggs/Kohler type" 3/4" X 16 threads 8-11 PSI Bypass Gasket 2.734"OD X2 .430"ID 0.226" thick
Length" Wix Purolator Hastings Kohler B&S Baldwin MotorCraft AC Walmart JD
2.3" 57035 NA LF503 2805001 492932 B7165 NA NA? NA ?
2.7" 51056 L35310 LF302 1205001 492056 B1410 NA PF2210 NA AM125424
3.4" 51348 L10241 LF157 5205002 491056 BT223 FL793 PF53 ST3614 AM101207
4.8" 51516 L20195 LF134 NA NA B243 FL400A PFL400A ST3600 ?
I use the same Kohler filter, usually about $10.50. There is a 'NAPA Gold' sold at NAPA for about the same price. I don't have the number here but they can reference for you. I'd like to find a less expensive one myself.
I have been using the ST3600 for about three years now and i like the added capacity. No problems as of yet.
I've been using Puro L10241s on my 15hp Courage (Gravely ZT) for the past couple of years. Based on the lengths motorcity listed, I can see where the longer filters could be a problem. The 10241 fits with room for rags underneath (keep spillage off the transmissions) along with space to work a socket wrench cap for removal.
-Brent
Yep. I've used the ST3600 on my Kohler Command 20. In fact, I think that's what's on there right now. There's no reason to use Kohler oil filters.
Joel
