You don't get it!
We were talking about top and bottom bypass in the context of Motorcraft made by Purolator vs Purolator made by Purolator. Right? Understood this point so far?
As I've shown in two links, it is already understood by *most* people what is the difference between a top and bottom bypass. Right? Understood this point?
So in the context of the bypass, in the context of Motorcraft / Purolator, it is ok to use the terms top and bottom because a top bypass and bottom bypass are already understood terms.
Now if you want to call it a dome bypass or a base bypass, that's up to you. I certainly wouldn't spend my time trolling you on that, because I can figure out what you mean.
So perhaps you can stretch your tiny mind a little and understand that because people *already* refer to the bypass as a top or bottom one (you can find the same elsewhere on these forums), it was ok for me to talk about a bypass being at the top or bottom of the filter.
Comprende?
Of course, I do accept that there will always be people like you whose sole mission in life is to take people's discussions out of context for no reason.
For that reason, you may have the last word on this as I'm removing myself from this thread as I want to stop doing this to you:
