Originally Posted By: Californiabob
since it's only 3 quarts go for it.
15K is way too quick. but you may drive the car HARD in which case, I'd change the
brake fluid, and motor oil just as frequently.
and if you decide for maxlife - Walmart has it for under 4.50 per quart in the gal container.
and I've used it in aisin transmissions with NO but minis may be different.
The engine is a tiny, high-pressure TGDI... it's on a 5k OCI.
Brake fluid every 2 years.
The entire ATF system is about 6 quarts, so if I replace 3 quarts every 20k miles, the fluid will stay fairly clean, which is what I'm after.
