Its not a car, it's a full size van and nobody cares to see pics.
The cat is a magnaflow, installed in 2004 iirc.
Throwing a 25$ coil at this is not going to break me financially, Better than it failing when I do not have a good product choice.
Wires are known to get baked into submission under the reflective parabolic mirror of a tight fitting engine cover. So would the coil, I Imagine.
I've bumped ignition timing back upto 16BTDC, it was @ ~10degrees btdc for the test as that is what the label under the hood states it is to be.
Elevated hydrocarbons might mean I am not getting the MPGS I otherwise could. Hard to say with around town driving sitting at lights so often.
My noisy Airpump has become noisier in the last year. Perhaps it is not injecting as much air as it once did.
Disconnecting airpump means a seized airpump in short order, and new check valves as well. They've gotten pricey, I just leave it connected now.
