John Deere 7830 6.8L 150hrs/1 year - HPL 15w-40 CK-4 Cold Climate
wwillson
Staff member
Colorado
This is the first sample from this tractor of HPL 15w-40 CK-4 Cold Climate. The previous oil was Northland 15w-40. The HPL has been in the sump for 150 hours and 12 months. Our plan is to run this oil and only change when the UOA says it needs to be changed. With a sump capacity of 28 quarts, it's pretty expensive to change and there is no reason to dump good oil on a rote annual oil change. This oil will be sampled next spring and should have around 300 hours. Given the very dirty environment Ag machinery runs, the Si is quite low. The JD engine air filtering system is doing a great job.
[edit] I forgot to state that this is the 15w-40 Cold Climate formula.
Sample Information
Sample Date3/25/2023
Machine Time hours1,800
Oil Time hours150
Filter Age hours150
Oil ChangedNo
Filter ChangedNo
Make-up oil0
BrandHPL
Viscosity15w-40 CK-4
Wear Metals
Iron22
ChromiumTD]
Nickel0
TitaniumTD]
SilverTD]
Aluminum2
Lead1
Copper2
TinTD]
Vanandium0
Cadmium0
Additives
Boron17
Barium0
Molybdenum483
Manganese1
Magnesium917
Calcium2431
Phosphorus990
Zinc1184
Contaminants
Silicon9
Sodium1
Potassium0
Fuel %TD]
GlycolNEG
Soot%0.2
Fluid Condition
TBN17.58
Viscosity14.2
[TD]
[TD]
[TD]
[TD]
[TD]
This is the first sample from this tractor of HPL 15w-40 CK-4. The previous oil was Northland 15w-40. The HPL has been in the sump for 150 hours and 12 months. Our plan is to run this oil and only change when the UOA says it needs to be changed. With a sump capacity of 28 quarts, it's pretty expensive to change and there is no reason to dump good oil on a rote annual oil change. This oil will be sampled next spring and should have around 300 hours. Given the very dirty environment Ag machinery runs, the Si is quite low. The JD engine air filtering system is doing a great job.
Sample Information
Oil Time hours150
Filter Age hours150
Oil ChangedNo
Filter ChangedNo
Make-up oil0
BrandHPL
Wear Metals
Iron22
ChromiumTD]
Nickel0
TitaniumTD]
SilverTD]
Aluminum2
Lead1
Copper2
TinTD]
Vanandium0
Cadmium0
Additives
Boron17
Barium0
Molybdenum483
Manganese1
Magnesium917
Calcium2431
Phosphorus990
Zinc1184
Contaminants
Silicon9
Sodium1
Potassium0
Fuel %TD]
GlycolNEG
Soot%0.2
Fluid Condition
TBN15.85
Viscosity14.2
[TD]
[TD]
[TD]
[TD]
[TD]
TBN Wow!
The Visc. & TBN are doing very well. You're right about the silicon being low for a real dirty environment. This is always a joy to see "Off road" equipment UOA. Thanks for posting this one. It'll be interesting to see how the HPL pans out with double the runtime.
Looks good, overall. Very likely that extended OCIs are going to be successful here.
How are you going to track wear rates?
Per hour? .146 ppm of Fe
Per 100 hours? 14.6 ppm of Fe
Or convert it to an equivalent "per mile" basis? (assumed avg = 35mph) 4.2 ppm of Fe per 1k miles
Did a VOA get taken? Just curious if a base number for the Si is known? The rest of the contamination is very low, especially the soot for 150 hours of exposure.
What kind of service factors does this see? Heavy loading all the time? Light loading? How much idle time?
Probably per 100 hours. I don't think it makes sense to convert to MPH, because tractors might average 4.0 MPH, so the comparison may not be valid.
No VOA, but we can get one.
Medium loading most of the time and not much idle time. We don't like to work our engines to the limit, because they will not last as long. Overhauling these engines is a very expensive endeavor.
I find these newer 15W40's that have really excellent cold flow numbers very interesting. HPL cold climate lineup is crazy good but there are even some others that are making 15W40's that, on paper anyways, look more like 5W40's.
That TBN number is.....wow. Great results.
Shell’s take on a “cold climate” 15w40 diesel oil is basically that it’s a synthetic oil.
I plan on using their 15w40 oil in my tractor next year. Using Amsoil right now.
