JD LA110 Resurection
Project Update 2 July
Stopped by an auto parts store this morning for B12. Dumped a few ounces in and started the tractor. I noticed that it would go to full throttle without hunting or surging before that B12 had a chance to get to the carburetor. Encouraged by this I took it for a drive and would estimate that it went 20 seconds before surging again. I continued to let it idle at low speed and take it for a drive around the yard. Sometimes it would make it only ten seconds before surging; other times it would make it thirty seconds. Engaging the blades seemed to cause it to surge almost immediately. I ran it for 25 minutes today so the B12 has definitely had time to make it to the carburetor.
I can see some grass and unidenified black stuff in the fuel tank. The fuel cap doesn't appear to be disintegrating. It should be out of fuel soon if I keep up these exercise runs. Once that happens I will try to vacuum out the fuel tank. It seems as if I should remove and clean the bowl. Also need to check the air cleaner for a rodent nest.
I would clean the OE carb first along with the fuel filter change. Those off shore cheap knock off carbs are very hit or miss.
Thanks. I do believe that fuel delivery from the tank to the carb needs investigation. Is my plan to completely empty the tank and vacuum it out sound, or am I at risk of blowing up my shop vac? Luckily there is no urgency to this project. The battery appears to be toast so I may just get a new one on my next trip to WallyWorld.
NO SHOP VAC TO DRAIN A GAS TANK. Unless your looking to meet your maker and make the evening local news.
Tank under the seat just use some compressed air. not too much pressure, and let the old gas come out at the fuel pumps inlet hose connection. New filter will finish job.
Sorry - I meant after the tank was empty and fully dry. There's a fair amount of grass and other stuff in there.
Project Update 3 July
I went over to the MIL's again today and fired up the tractor. The good news is that it starts easier every time I visit. The bad news is that the B12 doesn't seem to have done anything. The engine still surges and hunts shortly after it goes to full throttle. The problem seems to get worse under any kind of load.
I checked the air filter and found it to be in pristine condition. Whoever serviced the machine in 2020 obviously changed that out as well.
There is still a fair bit of gas + Seafoam + B12 in the tank. I would estimate that to be somewhere in the neighborhood of 1-2 quarts. The immediate plan is to keep running it every few days until this fuel mix is gone. After that it will be time to address the fuel line, fuel fiter and also clean the carburetor bowl. Any other suggestions are welcomed.
As an interesting aside, the starter won't so much as click when I arrive. After ten minutes of running the machine will start on its own. That's rather odd for a neglected five year old battery.
..The good news is that it starts easier every time I visit. The bad news is that the B12 doesn't seem to have done anything..
A few years ago, I began mowing my wife's Aunt's lawn with the Aunt's circa 2017 John Deere Z535M which was only used sporadically before I started using it. It was surging pretty bad when not under load. The only things I did to remedy it were to install a new air filter, put Seafoam in the gas, and run only 100% gas (no ethanol) in it. The surging went away in one mowing season.
Have you taken the top cover off yet to check the cooling fins? A mouse nest etc will cause overheating.
I think you are counting too much on the gas additives to clean things. You may need to take the carb off and clean it in an ultrasonic cleaner.
I would check any gas containers they have hanging around. Grass got in the tank through some way.
Project Update 4 July
We visited the MIL again today and started the tractor. The good news is that it now starts unassisted with its five year-old battery. That's pretty amazing. The bad news is that there is no improvement in terms of surging and hunting at high throttle. The Seafoam and B12 have had their chance. They did improve thngs but now I will need to tear into things. Film ayt eleven.
Yesterday I had a look at the MIL's John Deere LA110 lawn tractor. I don't believe that it had been started in three years, possibly four. It had gas in the tank and caburetor the entire time.
Step one in the process was to connect my Gooloo 4000 jumper battery. There wasn't even a click on the first go. After pressing the boost button on the GooLoo it started turning over. After seven or eight cranking sessions it actually fired. Suffice it to say that I was pleasantly surprised.
Step two: checked the fuel level and found it to be pretty low which is a good thing. I had brought along a battery powered transfer pump but hadn't bothered to check the battery status. You all know how that ended up.
Step three: dumped in a healthy dose of sea foam. Initially the engine wouldn't run without full choke. Later it would run at full throttle but was surging or seeking.
Step Four: spiked the old fuel with new 90 octane E0 at an estimated 3:1 ratio. After a few minutes of this mix it would run at mid throttle, still surging. Took it for a few laps around the lawn at this point.
Step five: went over the next day and fired it up again. It is starting much easier now. It can go down very close to the lowest throttle position without stalling and seems to run very smoothely at low to mid throttle. It still surges at full throttle, be that stationary or when driving. Seems like we have a fuel delivery problem.
Step Six: spiked the fuel with even more Seafoam. Having this soaking in the system is probably a good thing. Tomorrow I plan to fire it up again and move more fuel through the system. Any other suggestions at this point? Note that someone was under the hood in 2020; it's had no attention since then.
If it has a fuel filter, it wouldn't hurt to replace it. If not splicing one in would help. An old guy that works on lawn mowers near me said to always check the float bowl as it may have crusty junk in the bottom. Now that seafoam has cleaned up the fuel system it might get sucked up into the carburetor.
Project Update 17 September
I stepped away from this project in early July but did occassionally start it and take a few laps around the lawn. As of about 17-18 August I left the battery on charge overnight but the machine still wouldn't start. No surprises there given the battery dates from 2020. As of that time the engine was still surging at full throttle.
It had been suggested earlier that the fuel cap might be disintegrating and sure enough it was, so I replaced that. As of today the machine seems to be running just fine under load at all but the very highest throttle setting. The Seafoam and B12 appear to have done there thing. Now I am wondering if maybe the choke is sticking or needs adjustment because choke is just past full throttle.
Project Update 20 September
Started the tractor today hoping for a continuation of the last experience. Nothing doing. The engine was surging at mid to high throttle just as bad as it ever had. I let it idle for about 5-7 minutes and took it for another lap around the yard. Wouldn't you know it but the surging completely vanished.
So what are your thoughts? Carburetor problems just don't come and go like that. We know that the battery is toast but have also noticed that the headlights don't work. Maybe both bulbs are shot or maybe we have a larger electrical problem.
My intentions at this point are to replace the battery, use the machine to tow my 21 gallon tank sprayer around the property for broadleaf weed control, then sell the tractor. I just don't like the idea of selling something with an unknown problem.
