Even if it’s not, bringing in the supply through the outside wall could be a good option. Then just run it through the wall to the sink.Is that bathroom on an outside wall ?
NoIs that bathroom on an outside wall ?
Yeah, job one is to avoid the slab. I added a shower to our utility room to be used by the pool crowd - I had to raise the floor on that end - but with a nice HD handle and a grippy step - it serves the purpose …Even if it’s not, bringing in the supply through the outside wall could be a good option. Then just run it through the wall to the sink.
This seems like a better solution. Find a plumber who can think literally outside the box.How cold does it get there? could the lines be run up and outside wall and through the attic, then down, insulating the lines of course.
...Dunno how you would run pipes above the slab without tripping over them.
As said by a few others, re-pipe using PEX.The sink in our front bathroom has not worked in many years. I was pretty certain I knew why but let it be as I'm no Plummer and it's a problem that's bigger than I can handle.
Wife decided to call a Plummer out of the blue yesterday. Never told me untill I got home.
He confirmed what I had assumed.
The pipes leading to the sink are rusted shut.
He gave her a $12000 quote to repipe the problem which includes jack hammering the foundation up.
I can't afford that but she wants the sink to work.
Now this is a silly question I'm sure.
What are the chances of me causing a leak by say putting vinegar in the pipes to eat the rust? How about blowing them out with compressed air?
I certainly do not want to cause a leak.
Metal pipes in the slab what year was the home built?The sink in our front bathroom has not worked in many years. I was pretty certain I knew why but let it be as I'm no Plummer and it's a problem that's bigger than I can handle.
Sounds like it's the drain line. Turn it into a storage room. Cut the water off to it.The sink in our front bathroom has not worked in many years. I was pretty certain I knew why but let it be as I'm no Plummer and it's a problem that's bigger than I can handle.
