JHZR2
Staff member
I guess you could question the nature of why this happened - simple mistake as it is.
I use a torque wrench on my drain plug. Not really necessary, IMO, but it requires me to take another step, which effectively verifies that I put everything together properly, since Ive torqued the cartridge filter top and the drain plug.
I learned myself in the opposite way... When I first had my first w123 MB diesel, I was learning how to do the oil change. For whatever reason I loosened the bolts on the cartridge filter, but then determined it was too late/dark to do. The next morning, I went out and decided to start the car to let it idle a bit first, so to get a warm/hot oil change. I asked my 13 year old brother to watch the car while I did a few other things.
Well, after a little bit, oil started draining out of the filter top... and make a big mess/puddle. The car had a vacuum operated shutoff, and the car had low vacuum in the shutoff system at the time, so turning off didnt help. My poor brother didnt know what to do! By the time they got me, probably a gallon of oil was on the driveway, spilled out of the filter top! Fortunately the car has a manual shutoff on the injection pump!
