Originally Posted by Mad_Hatter
Incredible that someone would actually make the case for NOT replacing the brake fluid regularly... it's not like your life depends on a brake system that functions optimally or anything. Just wow...
Not at all incredible. It's senseless to change something before it needs changed, unless a known end of life is imminent, for example a 5 year old battery and you drive desolate stretches of road or in freezing conditions. If you have spongy brakes, or severe driving situations where you're getting the fluid really hot (odds are you have the wrong vehicle or are driving like you stole it) then a short period, every year or two makes sense, or even before every track day.
If you do not have one of those extreme situations, brake fluid being hygroscopic is fairly irrelevant if there's nowhere that moisture is getting in. Say you have a fluid reservoir you can check without opening it, and it does not draw in external air to displace fluid as the pads wear. In that case it could be many years before you get enough water buildup to matter. A tiny amount can get in through the rubber soft lines, but the rate of that is trivial. A hydraulic system is necessarily sealed with the exception of the reservoir fluid displacement.
The safety argument doesn't wash. Your life depends on your ball joints working too but do you change those every two years regardless of whether they have any problems? How about the brake master cylinder, change it every year because if it fails your brakes will? Brake lines too? Wheel cylinders? No. It is not sane to argue to replace everything before any sign there is a problem. You'd be doing nothing but working on your vehicle every weekend.
Show us the accidents attributed to dirty brake fluid? If an automaker did not prescribe changing the fluid and that resulted in massive accidents, this would make the news in a big way as a defective brake system. If you're suggesting your use is special and will cause your brakes to fail when everyone else's aren't, then indeed your special use could benefit from more frequent fluid changes.
Sometimes I see people suggest it will cause brake line rust-through, but I've never seen that happen from the inside out, it's always the outside that rusts out first. Maybe today with more vehicles having plastic coated line it is more true, but would tend to take decades and by that time, you'll have other brake component failures that cause the lines to be bled anyway.
I have never done a brake fluid flush every two years and have never had a related problem. The vast majority of people don't change their fluid every two years so again, this is something that would make headline news and cause industry wide recalls if people were dropping dead like flies from oil brake fluid caused accidents.
I get it. Brake fluid is cheap, and most people can DIY, and it's unlikely to cause any harm as long as the bleeder isn't rust seized, and a decent quality wrench is used, and fresh fluid not a partially full old container that absorbed moisture, but the facts matter and the fact is, of all the things that cause vehicle accidents, old brake fluid doesn't register as a common cause.
If it's a lives-at-stake argument, then the very low cost isn't a factor. Lives at stake would mean you replace all the more expensive critical parts every two years too.
For example, a substantially (orders of magnitude) larger # of accidents happen due to tire failures, so do you suggest everyone should replace their tires every two years?
Do what works for you. Me, I consider a brake system that needs new fluid every two years without a special cause, to be defective.
