Originally Posted By: ZeeOSix
Originally Posted By: boosted
Car makers call for a certain filter for a reason, it has to do with oil pressure, every person here probably knows that more oil pressure equals a happier engine, by sticking a longer/ bigger filter on all you are doing is wasting money by having to use more oil and loosing much needed oil pressure at the same time ...
You don't lose oil pressure from using a bigger oil filter. In fact, a larger oil filter may reduce the flow restriction which in turn will make the positive displacement oil pump work a little less hard to pump the same volume down the oil circuit. If less restrictive, it will also give you more oil pressure when the oil pump is in pressure relief mode.
also less of a chance for the bypass valve to open up
Yep ... and also more debris holding capability. There are many advantages to using a larger sized oil filter IMO.
And, aside from possible installation difficulties, no downsides I can think of.
