If you had to choose 1 oil and the only visible spec was....
So Cal
Ok, 2 quarts of Synthetic 10w30 oil in unmarked containers.
One has a "CI-4" rating, the other has an "ACEA A3" rating, that's it.
Which oil do you choose to put in a gas, V6 truck engine for 5,000 OCI's?? And why! (temp 35f-112f)
Darryl
[ March 28, 2005, 04:56 PM: Message edited by: Darryl ]
Well, I haven't followed the different ACEA ratings and such ..but I'll tell you if I ran into a synth in the USA that meets CI-4 specs in a 10w30 ..I would doubt the label if it was sold south of the Canadian border ..or didn't have an Amsoil label. Amsoil is the only synth that I know of south of the boarder that has a CI-4 rating and isn't a 5w-40.
Was this a trick question???
Both are probably overboard for such an application, but I guess I'd chose the A3 one, unless it was a sludge producing motor.
-T
No it's not a trick question, and it's certainly not AMSOIL!
I'd rather not say what 2 oils I'm deciding on, but one is sort of green, and the other is sort of purple.
Darryl
P.S. I know the green one is a 0w-30, I asked about 10w30 because thats the viscosity of the purple one!
[ March 28, 2005, 05:33 PM: Message edited by: Darryl ]
Myself, I'd pick the ACEA one without knowing anything about the truck or usage.
You know, that's interesting. There are several common dino CI-4 oils in 10W30, but no common synthetics that I know of. Hmmm...
If the oil ONLY had a CI-4 rating, then I would not use it in a gas engine. CI-4 is only suitable when accompanied by the appropriate gas engine rating.
According to their website, Redline's 10w30 is CI-4 rated.
Darryl
Strange, I just drained out some GC and put some 10w30 RP in. I am doing an Analysis on both to see which works better for me.
I have 2 diesel trucks so the CI spec is a must for me, and is also works super in a spark plug engine.
The other problem is my AZ does not carry the Green and the Purple is $4.29 and API approved and available locally.
I'd definitely go for the ACEA A3 or A3/B3 or the new C3. That's largely because I like the higher HTHS.
As for the Why(?). Even though my engines are not high performance I figure if the A3 holds up and protects well under such grueling conditions it'll have an easy chore of protecting them. In other words, just a tad overkill on protection.
Thanks to you all! I was just trying to get a feel for different opinions regarding the A3 & CI-4 spec,
while trying to keep personal preferences about the oil brands themselves to a minimum.
Obviously, I'm choosing between GC and Royal Purple 10w30
Darryl
CI-4 is for diesels only, unless it also has a gasoline engine spec on the label.
ACEA A3 is their toughest gasoline engine oil spec.
Go A3.
Ken
I'd want ACEA A3 - and ACEA B4, to get the added detergency needed for TDI diesel applications. Very useful in any long drain application as well....
TS
