Originally Posted By: billt460
Anyone with a pressure washer use this stuff?
https://www.grainger.com/product/45TP60
When you're finished using your washer, you screw it into the low pressure hose inlet into the washer pump. Then with the ignition "OFF" you pull the engine around a few times while spraying this into the pump. It's suppose to help keep everything lubricated, and prevent any corrosion and mineral deposits. Seems worthwhile for $8 bucks, so I picked up a can.
I also bought a bottle of this, per the Kohler operating manual. It's supposed to offset the effects of Ethanol in fuel, and help prevent any rust and corrosion in the fuel system.
https://www.walmart.com/ip/ETHANOL-SHIEL...13=&veh=sem
I've also got Sta-Bil, and Sta-Bil 360. So I have enough additives to preserve my fuel until the Asteroid hits. I won't be using this thing very often, and I don't want the engine to get gunked up from sitting.
I use RV anti-freeze, Prestone green, or G05 works too, the RV stuff is cheaper. I have a small hose with a funnel on it, that screws into the water inlet. With the engine in the off position I pull the cord until the anti-freeze shoots out of the pump. I remove the funnel and fold the hose over itself and clamp it. The pump doesn't corrode and it won't freeze over, which is a concern here. I use 89 Octane gas, Marine formula Stabil, and a UCL in the gas. I estimate one of my power washers to be over 30 years old now. Stabil Marine hasn't been around as long as the machine, but the method I mentioned has maintained it. The pump is still the original and hasn't been rebuilt yet. It has seen commercial use and ran several hours a day during the exterior painting season.
