I am going to have to put this head on myself.
Clean the bolt threads with a wire wheel, or with a die. Clean the block threads with a die, or the home-made thread chaser that Trav described.
Thread the bolts into the block and see how smoothly they turn. Again, bolts must be clean, parts must be clean, or this won't seal.
The torque on your head bolts is an approximation for the proper amount of bolt stretch. The stretch on the bolts is what provides the clamping pressure to keep everything sealed up right, even over the differential expansion of aluminum (head and block) and steel (bolts and liners) with respect to temperature. The shop manual will give you the torque specification and will tell you if any special conditions are required (dry, lightly lubricated, etc...). Often, bolts are torqued to an initial value, then angle-torqued for the final step (e.g. Tighten first to 25NM, then to 50NM, then an additional 90 degrees).
If the torque is spent overcoming resistance from gummed up threads, then there will be insufficient bolt stretch and insufficient clamping force. You MUST clean everything completely.
Only then can you evaluate the condition of the block threads, and only then can you torque things properly.
If the threads in the block are damaged, you'll have to install a time-sert. This requires precise drilling and precise installation of the insert itself. Time-serts are expensive, but cheap when compared with new engine blocks. Get help if this is the case after everything is cleaned up. I would not advocate learning how to drill and install a time-sert on this car. Make a mistake, misalign it, even a bit, and your block is done. Time for a new engine.
The bolts themselves have a specification for overall length (or width) - if they've been tightened too many times, they will have stretched beyond that limit and lose the elasticity they need to work properly. In that case, they'll need replacement. You MUST check the specification.
Don't chase the threads with a drill. Especially in an aluminum engine block on something as critical as a head bolt.
Have you tried just blowing out the gunk and putting some ATF or something on the bolts and threading them in and out of the holes?
I have had to make homemade thread chasers before out of a nut or bolt but, usually, I can clean up [censored] threads by using some ATF or WD40 or Acetone/ATF and running the bolt or nut in and out a few times.
Originally Posted By: satinsilver
Originally Posted By: InfmousCornholio
*full time third shift.
Which vehicle do you drive to work?
Ahhh, that's the beauty of this zip code we call 07002 (Bayonne) ... I lucked out, and only have a 14 block, 10-12 minute walk in!
On rainy and or HOT night, I drove the Envoy...
IF I re-apply at Amazon this year my first choice would be the Honda. All highway...
And, I plan on having the Blazer back functional before snow gets here. (Also, if I start looking at cars from Zern's Auto Auction in PA, i will use Blazer as workhorse to tow them.. it's a drive from Norristown as well as NJ but they sell cars and PA prices.. it's a goal.)
This was taken almost leaving the 7-11 parking lot next to store manager's Olive - colored Impala (popular company car!,) to give you an idea of how close.
ATF/Acetone and I'm in!
Out of all the EXCELLENT ideas presented, this one is the easiest for me to first do.
You all should have an update on this tomorrow.. my "day off."
Wait - you plan to have the Blazer running in two months? It's been off the road for years with zero progress, right??
Pick one vehicle and focus on it. Complete one project at a time.
Just...focus...
Three days of posting and you've not cleaned the bolt holes? That's one tiny step on the way to fixing the Honda.
Did you get a shop manual yet? You can subscribe on line and download what you need. The trial subscription is cheap. You need to research and understand the task ahead of you. Then gather your tools and supplies.
And stop taking video while you drive - that's as bad as texting!
Yes, he can totally pull this off.
He's got all the skills needed to perform the work needed on the Blazer.
No need, he's that good at multitasking.
I mean, look at how well he's posting on this thread, and all the other threads, all at the same time.
No one ever tells him to concentrate on just one thread, you know.
Quote:
Just...focus...
His is razor sharp.
He's just getting himself properly amped up for the work that needs to be done.
Just like how an Olympic runner stretches before the race, he's got to make sure he's ready to handle this mighty task.
Yup, he said that he got one online a page or two back.
He's gotta stretch before he starts to read it, too, though.
Don't need him getting eye cramps, you know.
Multitasking!
He's the king of it.
I know I can't take a video while driving the same way he does.
And don't start looking for all the youtube videos created by me on youtube.
Those are just dashcam videos, and they just aren't the same quality of performance art that he gives us in his mastercraft.
BC.
Just...focus...
Quote:
Just...focus...
His is razor sharp.
Multitasking!
BC.
BC'S post aside....
Yes, I downloaded Honda FSM. Check.
Yes, the Blazer has been sitting around for quite some time. Check.
Yes, I plan on tackling Blazer after the Honda. Check.
I even feel motivated to put some 5w30 in the Envoy today.. probably Pennzoil Platinum Pure Plus, the natural gas based stuff. Video.
I'm going to apply for a Passport today, too...
And, since it's my DAY OFF, count on bolt hole cleaning.
Now, hi-ho, hi-ho.. It's off I go.
Who loves ya.
Sincerely, - Cornholio
ATF/Acetone mix
That's only for thread chasing right? I wouldn't recommend that on the pistons as I am not sure how it will affect the rings.
WD-40 would be good in the cylinders.
Brake cleaner for the bolt holes. Cover them with paper towels so the blowback doesn't get everywhere...including in your eyes...
The reason I recommended brake cleaner in the bolt holes is that oil, like ATF or WD-40, will sit in the bottom of the hole.
Oil in the bottom of the holes can prevent the bolt from bottoming out in the hole - so you you can't run them all the way down, and you can't get them properly torqued.
Brake cleaner evaporates - so it won't cause a hydraulic lock and prevent the bolts from threading completely...
If you've got to use a wrench to thread these bolts, and the bolts are clean, the threads in the block are still buggered up. Get a bottoming tap, or find a long bolt of the same pitch and make a thread chaser. You should be able to thread these by hand easily.
A wire brush chucked in a drill will help the bolts...chemicals alone are often not enough to clean a bolt or bolt hole that's been abused or has corrosion...both of which appear to be true for the Honda.
But the engine does look cleaner. And I can see the WD-40 in the cylinders.
That's progress. ...
