so i decided to do the drivers side front wheel bearing on my 2011 CRV. i have a on car HF style bearing tool seat. its kinda like the high end hub shark grappler style but less expensive i got the hub off with no problem. i put together the kit and started banging away at the bearing. the bearing would not budge. yes i did remove the snap ring i and using a ir 231 impact. keep messing with it for an hour. would not move.
Got frustrated and decide to remove the knuckle from the car and press it out. i have a HF press i got from my AK building days. its been in storage for a while so i put it back together and prayed the pump still worked. used the adapters and stuff from the HF kit. it took a lot of pressure but then a loud bang and i knew it was loose. kept pumping and it came out.
So i'm wondering why the HF on the car tool did not work. Does my air impact not have enough power? Do i need a heavier impact socket? watching south main and others that use that style of tool they make it look easy. i much prefer to do it on the car.
So you pros. Do you do it on the car or off on a press? Also, i have not bought a bearing yet. just get the best? i hope this fixes the whining i hear while driving. i did all the checks for a bad bearing ,but it did not show any of the signs. this was just a shot in the dark
Thanks for any advice
