I turned piston to TDC and carefully scraped off the carbon with an old butt chisel. Lotta soft carbon, the result of MMO dosage on the heavy side? I use about a qt a yr. The gasket didn't survive the 2nd head R+R. However that is fixed thanks to an E bay B+S gasket for 8.88 in the door. The air cleaner housing is now secured solidly to the carb and no more nuts will be ingested. I there is a fair amount of gasket stuck to the head. I considering running the head over the soft wire wheel on my bench grinder. The dedicated wheel is used for cleaning up bolts, and small parts. Would it be OK to buff up the head with it?
