Originally Posted By: Scott_Tucker
So are you saying the engine stutters after you start it, like it's misfiring, or do you mean it cranks slowly? If it isn't cranking slowly it's neither the battery nor the oil.
I wouldnt say its misfiring but cranks slowly. I know the easiest, less hassle way is to put in another battery but the place i bought it at, wont replace it under warranty if the load tests were fine.
Going to clean the battery cables and terminals right now and get the starter tested.
