How cold is too cold for Amsoil MCF 10w-40
Missouri
Hi guys, I recently purchased a Can-am Outlander 800R, atv. Has a 800cc v-twin engine--lots of fun! Anyway, I know amsoil makes a 0w-40 for powersports apps as well as a 10w-40 for motorcycles. I prefer the 10w-40, my questions is how cold is too cold for the 10w-40 as far as easy starting goes. Can-am says for "optimum all season performance run their 5w-40 syn". Any input??
-10F would be about the lowest i would go for occasional starts. below that I would prob go with the 5W although the pour point for the 10w40 is -51F. if you are running around on the thing at that temps then, well, you are braver than I am....
SAE 10W-40 Synthetic Motorcycle Oil (MCF) revised as of 6/07
Kinematic Viscosity @ 100°C, cSt (ASTM D-445)
13.9
Kinematic Viscosity @ 40°C, cSt (ASTM D-445)
93.36
Viscosity Index (ASTM D-2270)
152
Pour Point °C (°F) (ASTM D-97)
-46 (-51)
Flash Point °C (°F) (ASTM D-92) 234 (453)
High Temperature/High Shear Viscosity @ 150°C , 1.0 x 106 s-1 (ASTM D 4683), cP 4.52
Four Ball Wear Test (ASTM D-4172 @ 40 kgf, 150°C, 1800 rpm, 1 hour), Scar in mm 0.40
Noack Volatility, % weight loss (g/100g) (ASTM D-5800)
6.44
Foam (ASTM D-892, Sequence I, II & III 0/0/0
Shear Stability Kurt Orbahn (ASTM D-6278), % viscosity change 120 cycles 0.495
Rust Test - Humidity Cabinet (ASTM D-1748)
No Rust, PASS
Total Base Number
11
For "easy" starting, I'd agree with the above estimate of -10 deg. It'll still pump below that but you'd probably be better off with a 0w-40.
That said, keep in mind that kinematic viscosity ratings are only a very rough indicator of how a lube will behave. When you're dealing with good synthetics, it's possible for a 10w-xx lube to pump just fine at temps that might start to scare another 5w-xx. Amsoil is usually among the best for cold performance, so if you really like their 10w-40 but you're worried about the occasional day when the temp drops below -10, rest assured that you'll probably be okay.
I have absolutley no intention to even be outside if it's -10f. I dont know what it is but the whole "0w" thing seems too light. I know that it indicates cold start up weight but it just doesn't seem right.
I agree with Johnny the MCF 10W-40 will be fine, and also state you need not fear 0W-XX oils. Look at some of the BEST oils on the planet. GC, M1, etc all 0W-30/40's....oh yeah SSO as well...
German Castrol (Castrol Syntec) and Signature Series oil for amsoil, the 0W30, is there top offering
M1 has a reputation of doing very very well in the coldest of cold
My point is not to steer you toward 0W-XX oils, just saying:
0W-30 German Castrol (GC)
0W-30 and 0W-40 Mobil 1 (M1)
0W-30 Amsoil SSO
Are are fairly great oils in their own right, not a thing thin or wimpy about them. No need to turn in your man card when pouring them in.....well OK 0W-40 M1 does shear a bit with use, but this is as designed and that is a whole 'nuther kettle of fish..
People just say I'm such a nut for Amsoil. Dunno why...?
Just kidding. I really wasn't trying to be sarcastic or anything. You got it figured out! Let us know how she runs.
