Update. I have since found a crack between I & E on the #1 cylinder. Guessing this may turn into a valve job. Also with my luck as soon as I yanked the head I hear about this snowacane that dumped 6 inches on us. Have paper towels with WD 40 sprayed covering the cylinders and valley. I haven’t the slightest clue how to calculate lift and clearance with shaved heads and to complicate things I have high lift rockers.
Speaking of, I found gouges in a couple pushrods where they have contacted the exterior casting of the intake port on, and one valve has a circular wear pattern on the tip. I emailed the company I bought them from and was told maximum milling safe for Rockers is .03-.04 which isn’t exactly precise enough for me to feel comfortable chancing it so I’m returning the fel-pro gaskets and getting Cometic MLS Gaskets. Also was told to check lifter preload in regards to the pushrod problem which surprised me given an ASE Master Tech (exes brother) said torque and forget. I believe he claimed the shims set preload which thinking about it makes no sense. The lifter spring is weaker than the valve spring so the lifter is forced to take up the slack. Gaskets are .45-.66 depending on how much the shop decides to mill.
And is it absolutely necessary to deck the block or am I fine with a decent straight edge and my craftsman feeler gauge? I’m seeing very few folks either on YT or in forums who milled the block.
So yeah, this is definately something I will learn from cause it’s gonna run a few hundred just for the milling and gaskets.
