I have a 2015 Accord V6 and have the famous vibration resonance at idle in gear, worse with the AC on. My car has 104,000 miles and have done quite a bit of maintenance along with a few extra and just can not figure this one out.
Engine oil and trans fluid are always changed on schedule
Timing belt, tensioner, water pump was recently done
Changed all the engine and transmission mounts with OEM Honda parts because this issue seems like that would be the solution.
checked the exhaust and nothing is touching. All hangers are sitting right.
Cleaned the MAF sensor and throttle body
I have had the car on the lift multiple times and have been under the hood looking for anything out of place that may be transferring noise
I have done all this work and the issue is not any better or worse at this point. Also it just crazy that this V6 that’s suppose to be so sliky smooth sounds like a old clapped out 4 banger at idle.
