My wife’s ‘16 Honda Pilot just crossed the 100k miles mark. We've had this car since August 2016, purchased brand new, so a little over 9.5 yrs. Travelled across the Texas and a few times to Florida and back. Here are some interesting details about the car (they are for me, not sure if anyone else would care, but here you go anyways):
1. A total of 4,833 gallons of regular gasoline with an average mpg of 19.3. The total cost - 12,140$.
2. A total of 26 oil changes have been performed at various intervals, but mostly 3-4k miles (all oil changes were DIY). Different brands and viscosities have been used, and as of late i've been using Kirkland 5w30.
3. A total of 13 drain and fills were done with mostly DW1, and last couple of them I made a switch to Valvoline MaxLife transmission fluid.
4. Brake fluid was changed 4 times.
5. Rotors and pads (all around) were swapped out at around 40k miles (pulsation when braking at highway speeds). Lasted for 30k miles and had to be changed out again (this time rotors and pads from Autozone - still feel good).
6. Factory bridgestone tires were replaced with Coopers at around 33k miles. Didn't last as long as advertised, and were replaced with Michelen Defenders at 65k miles - best tires I've ever bought.
7. Lower control arms were replaced at 42k miles (warranty) - torn bushings.
8. External transmission cooler installed (DIY) at 42k miles - helps a lot with summer driving, cooler transmission temps.
9. Fuel injectors replaced at 48k miles (warranty), along with the start/stop button.
10. Engine air filer replaced every 15-20k miles. Cabin - once a year.
11. For whatever reason, the batteries don't last as long. I'm on the 3rd battery after replacing the original one at 32k miles.
12. Timing belt/WP/bearings replaced at 88k miles (DIY Asin Kit)
13. Front struts replaced at 90k miles (KYB absorbers, OEM bearing and miscellaneous parts) - 50% DIY, another 50% had to take it in after stripping the crown nut.
14. Spark plugs replaced at 90k miles (DIY) with NGK.
15. Recently developed a minor leak (not dripping, just sweating), I believe the oil pump seal. Ordered the PCV, should be in my possession this weekend, perhaps it'll help.
The car has some dent, dings and scratches, but interior is in a great condition. I suppose will drive it till it drives.
Y'all have a great day.
