Ok guys My gf needs an oil change (due to the fact im out of Pennzoil platinum to feed her car) But here is the catch. it is the second oil change I have done since switching and the car has gone about 5 k and so far has burnt up 1/2 quart of oil. Im going to add the remaining half quart tonight to get her through till I can get the oil changed. the engine is currently near empty on oil so im glad I checked. so my estimates are that she has burned up about 1 -1&1/2 quarts of oil over 5k of driving (mostly freeway)
So here is my question. Should I switch? obviously 1 quart over 5 k miles is nothing big but is it reason enough to change to a high milage oil? Im thinking about switching to valvoline maxlife full syn so that way my car and her car will both be running the same oil. But keep in mind this is only the second oil change. so should I just stick in there and go one more and see what happens?
Oreilly's currently has a pennzoil platinum deal right now. 5 quarts and a wix filter for 26 bucks. so thats awefuly hard to beat. at 25 dollars they are pretty much throwing the filter at you. So im thinking sticking out one more pennzoil plat oil change and seeing what happens and if it doesent get any better/worse Ill think about changing over to a high mileage oil which seems to have almost haulted oil burnoff in my car
Thanks
Sean Scott
Thanks
Sean Scott
