Originally Posted By: Hib_Halverson
As a fellow Z06 owner and a tech. writer who covers Corvette, I'm familiar with the LS7 engine and the premature valve guide wear problem.
Looking at your report from Blackstone, they tell you that the high iron number is most likely because of the cylinder head change and the expected short term high wear rate as the new guides break in.
I'd go 5000 miles and sample the oil, again.
As for the lean at idle issue, it's very unlikely that's connected with the high iron numbers.
I know you said you're looking at the Edelbrock E-Force blower but it the engine modified now? If so, can you list the mods?
Also, when the MIL comes on, what code(s) are set?
Hib,
Thanks. I'm very familiar with your articles, and your posts on Corvette Forum. I post there very frequently, and have tried to get help there and from the Edelbrock forum for my lean code issue.
I had planned on submitting another sample in 4500-5000 miles to see if the wear is contained. As you can see the previous oil samples were normal, and I changed the oil about 150 miles after the new heads were installed because the dealer screwed up the oil change after replacing the heads. They didn't fill the dry sump correctly.
The engine is completely stock. I have added a DeWitts radiator, and HO alternator thinking the codes were being set by low voltage at idle. That is when the code always sets. I can watch the STFTs climb when sitting at a stop light or at an extended idle. But it doesn't always do it. The dealer lapped the intake valves in the new heads which may have removed their protective coating, and I hoping that may not be causing my problem.
What bother's me is that it didn't set the P0420 and P0420 codes for the first three months after the install. I've been chasing it for almost a year now. A new tune from Edelbrock seemed to help a little, but it didn't fix it completely.
