Originally Posted By: Vailshred
Thank you everyone, never had so many helpful and quick replies ever on any other forum! You guys are great
Ok... so I should be getting compression test numbers at around 160-170ish. I was thinking that they were low because of rings not seated yet. Thoughts?
I will start a leakdown test next week. Im leaving town Tuesday and im full till then. I return on the 11th and will get right to it.
Im not leaking any fluids at all nor have I lost any coolant yet.
Should i drive it for a bit and see if power starts gaining with milage?
If you are significantly down on power and slightly down on compression, I have 2 questions/recommendations;
1: Are you 100% positive the cam timing is correct? One tooth off will affect compression numbers. Off at crank, all cylinders affected, but also not likely to run at all. Off on one bank, that bank's compression will suffer a bit.
2: During engine assembly, were the piston ring gap clockings staggered? In other words, if there are two compression rings and an oil control ring pack, were the end gaps stacked on top of one another or equal thirds around the piston? Stacked ring gaps can and will create compression leakage. Do you have access to a cylinder leakdown tester? This will help pinpoint a compression loss.
My comments aren't meant to scare, just some things to think about, in an effort to solve or diagnose the lack of power you mentioned.
