Who has swapped out the stock for aftermarket. Looking at flowmaster 50's . Delta 50 vs 50 HD ?
Thats what i was concerned with. How it would sound with MDS on.I have a 40 series on my 1500, left the factory resonator in place so it wasn’t obnoxious and I like it. Interior and exterior isn’t overbearing but there is some drone when it kicks over into MDS.
Marginally obnoxious is the perfect description! The most obnoxious is where you’re right up against the load/throttle limit like when you’re going up a hill…. And even then the radio can drone it out, I feel the vibrations more.I believe stock Ram 1500 and 2500 mufflers are the size they are to soak up the MDS noise.
I went full 'murica mode on my 2019 Ram 1500 classic hemi w/single exhaust and installed a mufflex muffler delete on it. It's marginally obnoxious in the cab when MDS kicks in. Other than that it sounds flag flyin' awesome.
The nice thing is the captive band clamps that hold the muffler in place make swapping in something 'exact fit' a super easy job.
Did you remove the rear resonator too?I believe stock Ram 1500 and 2500 mufflers are the size they are to soak up the MDS noise.
No Sir. It's welded onto the tailpipe section, so I left it as is, which I'm fine with as I wanted to keep the truck as stock as possible. I can't tell if it does any resonating at all with no muffler up stream of it. LOLDid you remove the rear resonator too?
Update. I just got around to changing the exhaust. I did the delete and left the resonator as you did. Its great. Not bad at idle or driving, but when you really step on it, its pretty sporty.I believe stock Ram 1500 and 2500 mufflers are the size they are to soak up the MDS noise.
Not my truck but this video is how mine sounds. I did not change the exhaust tip.
When I watched that video, what went thru my head was “the ‘70s called, and wants its exhaust note back.” No way I’d live 5 minutes with a sound like that on a $60k+ truck; around here that’s what most trucks just a few oil changes from the junkyard sound like.
Same here, I think the Magnaflow on my 2009 sounded better than my Borla on my 2005.I've always done Magnaflows on my 5.7s. I loved the sound.
We went Borla on both because you could get the black tips, which look factory, since both had black OE tips.Same hear, I think the Magnaflow on my 2009 sounded better than my Borla on my 2005.
