My present system is a Lennox.
12hpb30-6p
2 1/2 ton
12 SEER
30,000BTU
2002 Mfg. date
208/230v single phase
My question is what kind of energy savings can I expect by replacing the units with a new more efficient, say a 19 SEER, multi or variable speed heat pump and air handler.
I am not looking to go to a larger heat pump.
The 12 SEER system just cannot provide the heat required when the outside temps drop below around 25 deg. F.
At this point the electric elements will come on in the air handler to maintain set temp in the house.
It also fails to keep the house cool in the summer when the outside air temp is in the 90's. Inside temp will not get below about 78 deg.
The system is serviced every year and operating properly within it's design range.
Additional insulation is not an option in my homes construction.
Any info would be appreciated.
Thanks
12hpb30-6p
2 1/2 ton
12 SEER
30,000BTU
2002 Mfg. date
Thanks
