Results are in from my latest run of 5w20 use.
The details:
Truck: 1999 Ford F150 Supercab Flareside 4x4
Engine: 4.6L 2V SOHC V8
Oil Filter: Napa Gold (Wix)
Air Filter: Fram (in for 11,000 miles)
Driving: 50-60% freeway, this interval had a boatload of trailer towing (4000 lb trailer) - about 1000 miles, plenty of 4x4 off roading (mud and snow) and gravel road driving, several fully loaded firewood runs, etc... In other words, it earned its keep over the intreval...
Weather: Temps ranged from 90 F near the start of the interval to -20 F at the end.
Hav = Texaco Havoline
Valv = Valvoline Durablend
My thoughts: Iron and Aluminum wear are up slightly, but not out of line with trends and Universal averages. Cold weather at the end of the interval may have played a part here with long periods of extended idling at below zero weather. In any case, they are acceptable.
Obviously, as I posted the last time I posted a UOA on this truck, this is the new formulation of Havoline 5w20. Note the moly and boron additives. This similar, but not exactly the same as we see in Chevron Supreme 5w20. You will know that you have the new formula - it is VERY dark in coloration.
Havoline 5w20 viscosity (new formulation) starts at 8.0, so we aren't really budging there. TBN retention is down, but it is much colder than the previous intervals.
All in all, its holding its own just fine and i'm not giving anything up running a 5w20. Consumption is the same and I'm getting longer intervals.
I think I'll run another 6000 mile interval, we'll see how the rest of the winter goes. Looks like summer can run slightly longer with winter cutting the interval a bit.
Not bad for a $1.59 a qt **** water thin oil!
[ February 03, 2004, 02:07 AM: Message edited by: MNgopher ]
The details:
The first three are Blackstone, the last is Holt CAT.code:
Oil: Hav Hav Valv Valv
Grade: 5w20 5w20 5w30 5w30
Date: 1/04 9/03 6/03 1/03
Miles on Oil: 6004 5033 4984 4038
Miles on Unit: 96399 90392 85359 80376
Make Up Oil (qts): 1.5 1.0 1.0 1.0
Aluminum 5 3 4 3
Chromium 1 1 1 1
Iron 20 12 14 16
Copper 3 5 4 2
Lead 0 0 0 0
Tin 0 0 0 0
Moly 200 2 3 3
Nickel 1 1 2
Managnese 0 0 0
Silver 0 0 0
Titanium 0 0 0
Potassium 0 1 2 0
Boron 23 1 1
Silicon 11 9 9 4
Sodium 4 3 3 2
Calcium 2067 2219 2496 1980
Magnesium 33 30 8 12
Phosphorous 770 783 829 721
Zinc 936 1007 999 908
Barium 0 0 1
Vis 8.3 8.9 10.3 10.5
TBN 1.9 4.7 1.8
Flash 395 425 400
Fuel 0 0 0 0
Glycol 0 0 0 0
Water 0 0 0 0
Insolubles 0.4 0.3 0.5
