Originally Posted By: henni
Cooling systems should always be deliberately undersized to allow the system to run continuously and dehumidify efficiently. Have setup several system where a 2ton(24000btu) variable speed system (both blower and compressor, 23 SEER or higher) replaced 3ton,4ton systems.
One added benefit to the variable speed systems is totally silent operation.
This is my philosophy. 10k btu is not 2x as good as 5k btu for a window AC unit. We don't get "hot" but we do get some curse-worthy humidity and haze that needs the edge cut off. The drain hole from my rinky dinky window unit moves a nice stream of condensate.
When visiting my relatives in the north, I noticed that their outside compressor unit was maybe half the size of my compressor unit. Funny because if you include the basement, their house is probably two and a half times larger than ours. (NTX houses typically do not have basements)
It was explained to me that a larger unit would lower the temperature but not remove the humidity. A smaller unit will run longer and dehumidify better.
That's how it was explained to me.
When you run triple digit temperatures and 30% humidity for 3 months out of the year, you get about one + ton per 500 sq-ft or you get hot.
Another funny difference, the compressor units up north weren't mounted on concrete slabs. They had galvanized steel pipes that stuck out of the outside walls and held the unit up. May have just been the builder in that neighborhood.
