Harsh shifts in 2004 Impala 3.4L
Elgin, IL
I have a 2004 Impala 3.4L with 53k on it. It has been shift harshly recently. When the trans is cold it shifts butter smooth, but after about 15-20 miles of driving every shift is very hard. If I let the car cool for a few hours it shifts great again. That is for first 15-20 miles. Any thoughts?
Does the service engine soon light come on?Get it scanned for codes and one known code,1811 will probally come up
The service light does not come on. And the DTC scan performed by Autozone did not show any codes. Is is possible that an aftermarket scanner won't be able to read the transmission DTC codes. And yes the fluid has been changed, and none off the symptoms changed afterwords.
I had a 2002 Impala with the same problem, which acually became worse after a full transmission flush. In addition, there was a whirring sound coming from the left side of the vehicle in the vicinity of the transaxle. After doing some research I learned that it appears that this problem may be caused by a defective pressure control solenoid and GM has issued a TSB (#00-07-30-002B) for that issue. In my case, the harsh shifting from 1st to 2nd gear set codes that the transmission shop could read via a scanner. The GM 4T65 transaxle has a known problem with the planetary gearset wearing out early when driven under certain conditions. If you have not had a pan drop and filter change done I would recommend that service and use the latest version of Dexron, which is Dexron VI. You are at the point where fluid replacement should occur using the severe schedule. I strongly recommend that you avoid a full flush. I believe the flush I had done distributed dirt and metal particles throughout the transaxle exacerbating the issues I was having. I wish you the best of luck and that you can get some more life of your 4T65. We had our unit replaced at 84K miles due to the possibility of an internal failure.
Sonnex does sell an updated pressure control solenoid.AutoZone uses a code reader which only read codes.Any aftermarket including the Snap On Modis can read the transmission codes.
I have the same problem with my 2003 Impala w/ 3.8 liter @105000 mi. It started soon after I had a complete transmission flush. The shifting for me is a pre-mature hard shift when first accelerating. It seems to clear if I manually shift through 1rst, 2nd & 3rd gears & then Drive. I'll take it to the shop if it gets worse.
