We see a lot of oil filters cut open, a few fuel filters, and maybe some spin-on tranny filters.. but how many in-pan filters do we see? Not many! So I figured, what the [censored]?
I didn't want to cut the plastic with the dremel, and the metal portion was really pretty thick.. so I broke it open with a slit from the dremel, a screwdriver, and some pliers. Messy, but it did the job.
This was pulled out of our '01 Bonneville's tranny at around 150k miles. It's a Filtran model, unknown time/miles.. but you can probably assume it's got a few, if not all the 150k.
Unmolested bottom:
Beginning dismantle, you can see the side view of the top passages:
Better view of the passages in the plastic portion:
Close view of the "top" of the media:
Close view of the "bottom" of the media:
You can think of this media as a sock of sorts. Here you can see the hole the fluid enters from the bottom and is filtered through the media "sandwich":
Media opened up and laid out, inside view:
Close view of some of the inside; That copper looking piece would be more worrisome, but I've accepted that this tranny will be rebuilt by sometime next year:
Well, there you have it. I'll try to do the next one in a cleaner fashion, but it was going to take a lot of cutting for the dremel to get through that metal, and I only have one cutting wheel on hand.
Unmolested bottom:
