Originally Posted By: dparm
If I plug the USB DAC into my laptop, there is zero interference. Or if I switch to the motherboard's on-board Realtek HD audio, the problem is mostly eliminated (still a very slight hiss but the RFI/EMI is almost entirely gone), leading me to believe the motherboard is introducing a ton of noise onto the USB bus somehow. eVGA is allowing me to RMA it, so hopefully that will be the end of it.
If I recall, you mentioned this issue on another thread? I was curious of the outcome given all the suggestions.
So the LT eliminates the problem, meaning it's source related. On-board audio is 'mostly' clean. Sounds like either a noisy device, a high impedance AC ground, poor bypassing or a host of other things.
I too hear squiggles, squeaks, buzzes, all that annoying stuff. Very irritating over time...
Report back when you find the solution!
