Originally Posted By: FoxS
If you're really serious about doing your own repair work, depending on how involved you get you will sooner or later need a good jack and jack stands. There is no way around it, unless you plan on never doing a tire swap, or brake work.
A Miti-Vac is a great tool too.
I picked up 2 sets of 3 ton stands from HF for $16 each.
I'm going to use 1 set as insurance when the vehicle is on the ramp.
I'm thinking that I only need the other set of stands for rotations and possibly brake bleeding but even then I might not need 4 for bleeding. I let Americas Tire do the rotations with balancing anyway.
So do I need the second set of stands?
I'm planning on buying the jack when I have a job that needs it and once I figure out which specs the Mercedes requires.
Good move backing up the ramps with jack stands, you can never be too safe.
I have 4 sets of jack stands so I might be the wrong guy to ask if you need a second set. Over the years there have been quite a few times when I needed all four wheels off the ground at the same time. I recently started doing two oil changes at a time, so yes a second set of jack stands is a good idea.
