The rear sliding backlite on my truck was replaced under warranty due to a cracked frame (and the resulting water leak). This is a known issue on the 19-20 Ram 1500’s.
The dealer sublet the work to a local one-man glass company.
I am not too familiar with glass installation, but I believe that normal practice is for the old urethane to be ”mostly scraped away” and new urethane gets applied over the remaining residue.
After the install, I see black primer around the perimeter of the glass. Is this because the urethane was fully removed and primer was required?
Did the installer do an extra good job by removing all of the old urethane or did something unexpected happen?
Type of window:
Type of window:
