This is my first UOA using GC. I switched to GC after doing 2 cleaning/rinse cycles of Auto RX. I also added, I believe, 8 oz of LC with the initial fill and about 1.5 ounces per 1,000 miles.
So, what do you guys think?? The only thing that concerns me I guess is the silicon. I run a ram air setup that gets it air from the lower radiator dam, so I am susceptible to all sorts of road debris if my filter doesn't do it's job. I was running a Baldwin filter for the majority of this cycle and am now running as Wix (which has more pleats than the Baldwin I took out). I also always put a thin film of silicon grease on the rubber sealing surface of the filter to help with sealing. I don't know if this could be causing my silicon to be a bit high or not.
Paul
Paul
