I recently acquired a 2008 John Deere Gator TH 6x4 with around 350 hours. Its in decent shape, not all beat up...but it was commercially used.
It was supposedly maintained by a dealer, but I just found the transmission over 3 quarts low of fluid (it holds around 6.1 quarts according to the manual). I had a partial 2-gallon container of Mystik JT-5, and used the remaining oil to just get it to the dipstick. I took it for a quick ride (about 5 minutes), and using a longer "stick", I brought a batch of oil out of the trans and it was completely clear, no signs of damage like metal flakes. So we will see, I'll buy another container of JT-5 tomorrow to top it off. It made either a sucking or pressure release noise when I pulled the dipstick, so I checked the vent which seemed plugged...so I drilled it out (I know, its made that way for a reason; but I know what it will be used for) thinking it might have been pushing the oil out past the seals. The underneath is damp with oil (like a slow seep), but not wet. It doesn't seem to be actively leaking, no drips under the deal after an hour of sitting; but it might just be hung up in the dirt.
The engine is a Kawasaki FH601 19hp, I'm planning on 5w40 Schaeffers based on research on this forum. What is a common cross reference filter for this engine? Is it the same as a B&S or Kohler?
It has these crazy rear chain-driven spindles. How are the maintained? Do they have a grease fitting, or are they oil filled? How do you lube them (the spindles)??
