I have a Tecumseh powered mower that wasn't needed for a few years and sat.
Pulled it out, cleaned it up, and eventually got it started, ran poor so I removed the lower bowl on the carb and cleaned things out and it seemed to run well. Checked the oil and it looked like it was diluting with gas. Next time I tried to start it gas was pouring out of the muffler.
From the online research I've done, it sounds like the piston ring was stuck and this caused gasoline to wash the oil off the cylinder walls and also gas blow past the rings into the oil? Is that correct?
What I'm reading as a suggestion is to remove the plug and pull the cord a few times to dry the top side out. Then drain oil (gas contaminated) from crankcase and refill. Maybe squirt some oil into spark plug hole and pull a few times to aid in lubrication/compression? Should I try a heavier weight oil? It will be used infrequently, but in Florida heat.
Should I run it a couple minutes and change oil a second time?
I'm guessing if the piston ring was stuck it shouldn't be any longer, since the gasoline would have cleaned it. Hopefully the engine hasn't suffered damage from running a short while in this state but compression still feels good subjectively speaking.
