Trav mentioned that nowadays, engines are so well engineered/executed the he hasn't seen tapered engine upper cylinder portion when tearing down after a few hundreds of thousands of miles.
Yes that's a fact. I haven't had to use a ridge reamer just to get the pistons out in many years. I recently had the head of a VW AEG 2.0 gas with 200K on it and the cylinder cross hatch was still there, no ridge.
Compression was over 190 psi on all 4 (cold) the head had a crack in it behind a valve pocket, replaced the head, cleaned the injectors, new plugs/wires and timing belt kit and sent it on its way running perfectly.
This is common today, there is zero benefit to running a UCL in a modern FI engine, the biggest problem back in the day as someone pointed out was cylinder wash down from the carb combined with inferior oils (compared to what we have available today), the rings use to get all gummed up and the top ring would get starved of oil.
Electric fuel pumps don't need a lubricant, the bearings are sealed and never contact the fuel, the only real issue with electric pumps is when they loose contact with the fuel and over rev, the fuel also keeps the pump housing cool.
On vertically mounted pumps that have suction from the bottom running very low on fuel can expose the upper part of the housing which contains the rear pump bearing, repeated events can lead to over overheating damage of the pump and long term damage.
Modern injectors only need the fuel for cooling, not lubrication, the old pintel style may have benefited somewhat but not a modern disk type.
Cleaner especially PEA based ones can greatly benefit the injectors by keeping the nozzles clear of carbon deposits, on the older pintel style a solvent type cleaner is usually better in most cases because it works better removing varnish.
On the old injectors a regiment of alternating solvent and PEO type cleaners can benefit both the injector and help keep carbon accumulation in the combustion chamber to a minimum which is a benefit of the PEA.
Both type can help make the engine "feel" smoother because they are changing the burn characteristics of the fuel not because it is reducing friction in the upper cylinder area.
